08-18-2010 11:55 AM
Hi All,
I am getting ready to do RS485 communications using a form of 9 bit multi-drop protocol on my next project
(the first byte has the 9th bit set, the rest of the packet does not)
Now, I know that you can get the ninth bit by playing with parity bit (MARK or SPACE)
The problem is do I want to try: has anyone had success with this?
A few years ago, we did a proof of concept on this in C++: it failed
There was too much latency in the windows operating system: sometimes it worked, sometimes not
My baud is about 57.6 K
Any hardware or software recommends would be appreciated
Jeff
08-19-2010
09:20 AM
- last edited on
09-25-2026
11:07 AM
by
Content Cleaner
Hello Jeff,
All of our 485 devices should be able to work with the multi drop configuration. Here is a link [link removed; article no longer available] to a knowledgebase that talks about the using multi drop with 485. You can see all of the 485 devices that we offer. For the software to control it I would recommend using LabVIEW. We also have a knowledgebase that tells how to do 9 bit communication in LabVIEW. I do not have any personal experience doing 9 bit multi drop though, does anyone else? Please let me know if you have anymore questions. Have a great day!
Best Regards,
Adam G
08-19-2010 09:43 AM
Jeff,
I've not done any 9 bit protocol but I have fooled around with programatically asserting and deasserting the DTR line on 232 ports. I found the USB-Serial adapters don't work very well for stuff like this due to overhead/delays in the USB driver layer. Takes forever to assert/deassert a control line or change the parity mode on the fly. Best bet is to use something like a PCI or PCIe card thats plugged directly into the pc backplane.
08-20-2010 07:11 AM - edited 08-20-2010 07:12 AM
Hi Jeff,
I use the 9th bit protocol with LabVIEW and it works fine.
Sending: change the parity in MARK and SPACE like you said.
Receiving: In the VISA config file disable the replacement character (DisableErrorReplacement=1)
Ignore error after receive data (parity error)
Let me know if this works for you.
You also can use hardware that support this. I use this solution for a test.
Kees
