AG53131A labview driver
Hi guys,
is that anyway to get the labview driver for Agilent 53131 frequecy counter as attahced. I download the driver from NI but unable to control the devices even it is in remote state already. Appreciate if somebody can provide help.
thanks,
BS
(5,631 Views)
What happens when you run the code? What error do you get? What sort of physical connection do you have? Is the instrument visible in MAX?
(5,621 Views)
I use the example in the driver i had download. After 2nd time read the measurement, the counter seem like no response and if i configure 2 different function(EX: freq, Period) in different channel also face problem.
(5,500 Views)
That's a completely different driver now. Which are you actually using? What error message/code do you get?
(5,491 Views)
Hi Dennis,
Actually no error was shown during the vi end. But the thing is the counter is not able follow the instruction send by the vi. You mention the driver is complete different now? So, is that possible to let me know where can I can the driver? I google this driver for long time but end up only manage to get existing package.
(5,457 Views)
It's very clear that the code from your first image is completely different than the code in your second image. The first should be what you use.
(5,435 Views)
