Anyone got a LabVIEW driver using VISA for Keithley 6220 current source?
Hi
I could not find any "pure" drivers (with the drivers listed on NI/Keithley site you will need to install Keithley IO Layer and so on). What I did is I just used the send command from visa panel : like CLE, CURR 0.001, etc... but I did not need fancy commands.. If interested I can look for those files for you..(but again, there are not so difficult...)
regards
Message 11 of 14
(2,588 Views)
Hi
Thank you, but I was thinking rather about complex library (with proper Initialization, Configuration, Read, Close, Error Handling methods, as I've meantioned 2400 is a good example). Also I had some difficuilties with opennig these files with LV 8.6 ( I managed to omit this problem by opening them frst with 7.1 version and then with 8.6).
Message 12 of 14
(2,586 Views)
Hi Wito,
NI is interested in developing a LabVIEW PnP driver for this instrument but we haven't been able to get a loaner from Keithley. If you are able to provide the instrument, we could probably develop a driver this summer. Please contact us at instrument.drivers@ni.com if you are interested.
Vesna
Message 13 of 14
(2,566 Views)
Hi chrisger:
           I'mworking with instrument too.May you give me a copy of your drive?my email is wuqingfeng234@163.com
        thanks in advance
Message 14 of 14
(2,261 Views)
