Array to number
Dear All.
Here i have program with will update the output from the Array input every 2min. But i want to have  the value after each  minute in Number  rather than in array. How can i do it? I try it with index array that is only for the specificed index only.
Thank you
(3,158 Views)
Accepted by 6826PN
Simple mod. You would also want to add code to stop the loop when the last element is indexed.
(3,157 Views)
