Can I configure weather station by parallel port?
Hi guys,
I'm trying to design weather station via parallel connection. Is it possible to control the signal and receive the result through parallel communication? Because I could find any option for the parallel connection in the labview instrument input/output.
Mayuren
(4,420 Views)
new pc's even have no parallel port !
(4,416 Views)
Yes, That is true. I just want to know is there any possibility to use parallel port to interface in labview.
(4,413 Views)
No problem.
You have several alternatives. You can use VISA or you can use portIO directly.
Depending on your version of LabVIEW you can use portIO it directly (>8) or need some library.
With VISA you can control the parport as a printer. Send bytes and control and read statusbits.
(4,387 Views)
Hallo Albert!!
  Could you give some tips how to do it?  Because I need to control the parallel port, but I'm using windows vista with LV 8.5.1.... so the Inport and Outport doens't works... and  I tried to use visa... but ... since is parellel port.... there's no baundrate..etc etc... so how can I use ViSA do to it?? Or there's other way?
Thanks in Advance!!
Ricardo
(4,265 Views)
started a new thread with more informations here
(4,251 Views)
