Holly is right on, but I wanted to add that you are probably not going to be able to emulate a TV remote using your IrDA port. First of all, the VI's are designed to communicate using the IrDA protocol which is a much higher level protocol than most TV's are going to use of infra-red. Secondly, IrDA ports have problems when it comes to distances greater than a few feet.
Hope this helps.
Scott B.
Applications Engineer
