Can I use 3.3 V rail with the TNT4882?
I want to use the TNT488 with a PXA270 Intel Xscale processor.
My PXA runs of 3.3V for the IO and the Mem. I would prefer to interface without having to use level translators. Is this possible?
Do you have an application note for the interfacing between the two components?
Best regards
Dennis
(3,093 Views)
You must provide 5V to the TNT4882 VCC pins. 5V is used for the core voltage as well as the IO voltage. If you only supply 3.3V I believe the TNT4882 will stay in reset as it has a built-in voltage monitor.
Have you considered the TNT5002? It is a software compatible with the TNT4882. It uses 3.3V for core and IO voltage.
Each device has a datasheet with detailed timing diagrams. These should give enough information to interface it to your PXA. You can also post/email your schematic if you have any questions/concerns.
(3,088 Views)
