Connect hamamatsu c9525 to labview via USB port/communication error
Measurement &Automation explorer does not see the device.
It is performing read/write/query operations without error because it probably sees the port without anything connected.
The hamamatsu source should display REMOTE if it were connected to a computer but it doesn't.
How do I undo/delete this MAX project and start again?
How do I get this source to communicate with MAX?
Message 11 of 62
(3,723 Views)
Does it now work with the vendor's software and do you see a com port in MAX? That is all MAX will ever do. What are you writing to the port?
Message 12 of 62
(3,719 Views)
Max sees COM3 "COM3_hamamatsu" as I originally named it.
When I select it and press Validate => Successfully opened a visa session to "ASRL::INSTR".All of the parameters on this page are valid.
If I open VISA test panel, input/output ,press write
write operation (*IDN>\n)
return count: 6 bytes
the same for
/query/read.
This is the point where last time only write was working and query/read returned an error.
But now the source is not connected so no errors at all.
In all honesty, I don't exactly know what I am doing: my understanding was that visa should set up the communication with the device and that configuration would be used by labview.
But visa, right now, is not sending nor receiving anything to/from hamamatsu
Message 13 of 62
(3,717 Views)
I don't know what you mean by 'source is not connected'.
You should be getting a timeout error when you do a read. I'll ask again - is the vendor's software working like it did before?
Message 14 of 62
(3,715 Views)
no, it is not working:
COM port # is unacquireble!
yes: input com port #
no: click search button after reconnect the cables.
yes/3 =>
can not connect to com3.
click either ok of cancel after reconnect the cables
reconnect cables=> detected new device com3 11:43:51
now it is working. This is ridiculous.
I just unplugged and the replugged the cable.
Message 15 of 62
(3,712 Views)
ok:
so now, instead of 2 ports: com3 hamamatsu and lpt1 i get a third one
COM3
when I selected that one(com3, newest entry) and clicked validate : successfully opened a visa session et c.
AND "REMOTE" apeared on the hamamatsu display
good news
then I opened test panel/input/output
write
no errors
query read operation return 2 bytes
BC
error: visa hex oxBFFF0015 timeot expired before operation completed.
BC is the failure response from hamamatsu.
so, indeed, there is feedback, even if not the kind I was hoping for
Message 16 of 62
(3,706 Views)
Thank you for your patience and advice, Dennis !
Now I must deal with the error
it is  not the timeout value: I increased it to 15000ms and the result is the same.
write -ok
read -returns error
Message 17 of 62
(3,705 Views)
in page 18 of the attached manual:
"When creating your own program by utilizing control commands, the following command
is available. In all commands, it is necessary to be terminated by CR(Carriage Return)"
so I selected from visa/config/ input/output settings / termination character : Carriage return -\n
Nothing changed.
Message 18 of 62
(3,700 Views)
The termination character setting is typically used for a read. You also have the wrong character. The carriage return is a \r so append that to the command when you do a write - *IDN?\r
Message 19 of 62
(3,694 Views)
p.s. The above command assumes that the instrument uses it. I don't know if it does.
Message 20 of 62
(3,692 Views)
