03-31-2009 10:12 AM
I have asked this question as a sub question in one other thread which I started, but it seems complicated enough that I need to start a new thread for it.
I need to connect an external device (GPS) which has a USB port to the D-SUB 15 pin port of the PCI 1426 frame grabber. I know that the USB port has a power and ground pins and two data pins. I also know that USB sends out data in differential voltage. But I am not sure whether the frame grabber can detect differential voltage.
My requirement is to send triggering pulses to the GPS device and read the responses given by the GPS device. I am thinking of using the TTL I/O 1-4 pins of the 1426 for this.
Can any one tell me how this interfacing can be done?
Thanks & Regards,
Sandeep
03-31-2009 12:29 PM
04-01-2009 03:15 AM
Thanks Dennis.
Apparently I have under-estimated the complexity of the problem!! This is the first time I am trying to interface the D-SUB 15 pin port.
The device gives out information in TSIP (protocol) format. The reason I am not preferring to connect the device to the USB port of the system is the speed/latency constraint. I need very high speed and low latency and I thought that using the D-SUB port would provide this.
a) If I do away with the part of sending the signals to the GPS and only read the messages from the GPS, would the interfacing be possible?
b) One other idea that I have thought about is the use of a USB to Serial port converter. If I connect the USB port of the device to a USB to Serial port converter cable and connect the data pins of the serial output to the TTL pins of the D-SUB. Would this be possible? (In this option also I am alright with the idea of doing away with sending triggering signals to the GPS which can be operated in auto output mode.)
Please let me know your thoughts.
Sandeep
04-01-2009 09:07 AM
There are at least a couple of problems that I see. First, the instrument does not have a serial port. It has a USB connection and the only way it would appear as a RS-232 port is if the driver (inf file) you install on a pc makes it emulate a RS-232 port. Without a driver installed and the instrument connected to a pc, I don't know what the USB port on the instrument would do.
Second, even if the instrument had an actual RS-232 connection, you would have to emulate a RS-232 connection with the digital I/O lines. Correct me if I'm wrong but isn't the digital I/O software timed? I don't see how you could possibly generate the precise timing required for RS-232 at even the lowest baud rates.
The software timed digital I/O would also make it very difficult to capture the raw signals being put out by the instrument (if it would even generate the signals without a connection to a proper USB port). With software timed digital I/O, you would probably have at best, an acquisition rate of 1kHz. The instrument almost certainly streams data at a much higher rate.
