01-30-2008 09:02 AM
01-30-2008 09:23 AM - edited 01-30-2008 09:28 AM
01-30-2008 12:07 PM
01-30-2008 03:54 PM
01-30-2008 05:47 PM
I'm not yet at that level.
I thougt I can copy a Labview Vi to another Computer and Install die Labview runtime and DAQmx and it works, DAQmx allready contains an Labview Runtime of higher Version than 8.5 i've seen today.
Actually my programm is made with Visual C++ 2005, for now I needed the ni stuff for some Signal Express Project and this also can't work without TCP/IP with the scope.
To make a labview VI from my Signal Express Project is also not that easy like the videos tells, OK I got one but allready the IVI-Scope-Waveform-aquisition working in Signal Express fails in Labview with lot of Errors in NI Spy.
Also the IVI SubVIs in Labview seem to be as static as the steps in Signal-Express you have no connectors for all the options of the IVI-Drivers you set in the dialogs but I need a lot of extended functionality for my problems which mean setting that options with results of earlier steps.
May be I find a little more possibilities after some more days work.
Ingo
02-23-2008 09:02 AM
I find with TEK-VISA installed and NI visa them MAX no longer works (hangs)
Colin
