Disconnected USB devices remain in Measurement and Automation Explorer
Will this still help if the device has already been removed from device manager and no longer seen by windows?
Message 11 of 22
(2,096 Views)
Go to the Device Manager, If the USB is still visible even after being disconnected I would suggest talking to the manufacturer for help. For your windows PC, the device is still connected. Give it a try and let us know how it goes.
Alejandro C. | National Instruments
Message 12 of 22
(2,094 Views)
Im still a bit confused about your solution. The article describes what to do when a device is attached but you cant communicate with it. I have a problem where visa is still comunicating with a device that is no longer attached nor present in the device manager.
Message 13 of 22
(2,089 Views)
Can anyone help out with this?
Message 14 of 22
(2,072 Views)
Hi MDKF, Can you please provide screenshots showing this device entry in MAX and the device manager. Does the device appears under the list of  VISA Aliases? Check the article "How Can I Remove Resource Names From the VISA Resource Name Constant or the VISA Aliases Editor?". Back up visaconf.ini and move it to a different directory to allow VISA to regenerate the visaconf.ini, which would clear the problem. I hope this helps
Message 15 of 22
(2,054 Views)
Hi. The Ini file does not contain an alias for any of the devices this has happened with. I have attached a screenshot of MAX.
-Michael
Message 16 of 22
(2,049 Views)
Take a look at the article "Why is NI-VISA Unable to Control my USB Device?", I believe it can give you more information. I was thinking...if you uninstall everything and start from scratch perhaps you can avoid this issue.
Message 17 of 22
(2,029 Views)
Im not sure what that article has to do with this issue. The VISA driver installed fine, and the device is not in ap particular class.
Message 18 of 22
(2,026 Views)
Did you used the assistance of the VISA Driver Development Wizard? If not, give it a try! Instructions are here.
Message 19 of 22
(2,023 Views)
Yes I created the driver using the VISA Driver Development Wizard.
Message 20 of 22
(2,021 Views)
