Does anyone have a Hantek DSO-2090 working with labview
hello,
I have a Hantek DSO-2090 which I cannot seem to get working with the supplied labview VI. I have searched the board but have not yet found a answer other than that it likly has something to do with the function in the DLL. I have no way of modifying the dll function so I now need to see what else I can do. I wander if anyone else has used this DSO before and if so how in the world did you get it to work? I appreciate all suggestions and advice, other than to get a new dso as this is the one I am stuck with for now.
Message 1 of 13
(14,842 Views)
You did install their USB driver?
Message 2 of 13
(14,836 Views)
I think so, It installs automatically when you plug it in. Also it does appear to be running up to the point of a dll function call to "getchanneldata", to test that I put a indicator on the return value of the functions and they all return a 1(working) up to this specific function. Im still lost on what to do.
Message 3 of 13
(14,832 Views)
Without the DSO, it would be hard for anyone to help you debug the VI.
Message 4 of 13
(14,830 Views)
I was sort of hopping maybe someone who has this device might see this and have either a similar experience that was solved or atleast tell me what they did to get thiers to work. Im still hopping.
Message 5 of 13
(14,826 Views)
You can keep "hopping" or better yet hoping.  Smiley Wink
I have never heard of this brand before and the scope is appears targed towards a hobby/enthusiast market.
$190 for this instrument vs. $1000 for a low-end Agilent scope.
I certainly wouldn't be purchasing something like that for my job.
Good luck.
Message 6 of 13
(14,819 Views)
Mattx055,
You may find the following forum post helpful:
Discussion Forum: Error 1097, but unfamiliar with code and programming
Jared A.
Message 7 of 13
(14,812 Views)
Thanks for the link, I saw that one already and it appears to have no solution. This is why I posted this to see if anyone else had one working. Its probally a lost cause and will have to tell my boss that I need something else.
Message 8 of 13
(14,807 Views)
Mattx055,
I'm sorry that you aren't able to get this device working. I know this is probably a long shot, but have you tried contacting Hantek to see if they have any insight into the error?
Jared A.
Message 9 of 13
(14,804 Views)
Accepted by topic author Mattx055
Hey all,
It looks like I now have a solution. I had contacted Hantek and I think it took about a week for them to get back to me, though once they did get back to me I was able to start compuniating back and forth with a tech. The tech sent me another copy of the Vi along a copy of the dll which appears to work.  So I have attached the vi but I cant seem to attach the .dll due to its extention so I changed it to a .doc file which would need to be renamed with .dll incase anyone else ends up with this same issue.
Thanks to all for your comments.
Message 10 of 13
(14,786 Views)
