Duty cycle failure
I had asked this question already, but I hope I can get some good feedback/help from experienced users...
I am having a problem setting duty cycle value with EXT trig....(it works fine with INT trig, 0-100%) I cannot understand why Dcycle value fails for values higher than 34%....(not like INT trig case)
Could you take a look at 'hp8133A application function_mod2.vi' in 'setting' case?
one strange thing that I notice is the fact that instrument briefly switches to 33MHz before switching back to external freq. I just cannot find where I can fix this to make it work...
Thanks for your help!!!
(3,258 Views)
Please see the following forum post for how this was corrected.
Good work jjlee!!
http://forums.ni.com/ni/board/message?board.id=170&message.id=167969
 -Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,238 Views)
