02-15-2006 04:47 PM
I am having a problem setting duty cycle value with EXT trig....(it works fine with INT trig, 0-100%) I cannot understand why Dcycle value fails for values higher than 34%....(not like INT trig case)
Could you take a look at 'hp8133A application function_mod2.vi' in 'setting' case?
one strange thing that I notice is the fact that instrument briefly switches to 33MHz before switching back to external freq. I just cannot find where I can fix this to make it work...
Thanks for your help!!!
02-16-2006 04:41 PM
