E3649a
Hi
I am using RS-232 to talk to my E3649A power supply, I have downloaded the drivers and can set voltages and turn on and off the power, but I cannot read voltage or current, does anyone know why the serial port is timing out?
Matt
Message 1 of 12
(5,389 Views)
Have you tried using NI-SPY to capture the calls?
Curt
Message 2 of 12
(5,381 Views)
The Initialize function works with asking for the id but the Measure function returns a timeout error?
Message 3 of 12
(5,365 Views)
When it is set up as GPIB the Measure VI is fine. It seems to be only a problem with RS232.
Message 4 of 12
(5,351 Views)
Please answer my question.
Message 5 of 12
(5,344 Views)
Try using the Visa Test Panel for 'ASRL#:INSTR' in NI-MAX
send these commands
INST:SEL OUT 1\n
and
MEAS:VOLT?\n
and see what happens
Curt
Message 6 of 12
(5,342 Views)
correction
command 1
INST:SEL OUT 1\n
Curt
Message 7 of 12
(5,339 Views)
Yes, the initialize functions returns the information without timing out, however, all of the other queries time out. If I look at VISA attributes in MAX I see...Is Port Connected... VI_ATTR_ASRL_CONNECTED...ERROR- Visa (0xBFFF001D) The specified resource is not defined or supported by the reference resource.
Message 8 of 12
(5,270 Views)
That attribute is only supported by serial adapters from NI so ignore that.
I don't understand how one query can work but not another. Have you tried the VISA test panel as previously suggested or a terminal emulation program such as hyperterminal, putty, etc? The suggestion to run NI-Spy/IO Trace is also a good idea.
Message 9 of 12
(5,265 Views)
I have not tried another terminal emulator. This weekend I will try hyperterminal. I will also try without a USB to Serial adaptor.
I am not that familiar with NI Spy, but will also see what it can tell me about this failure.
Message 10 of 12
(5,261 Views)
