Elgar CW801
How do i control an Elgar CW801P power supply.
I need to setup the Power Supply for different Voltages and measure the Current.
I need to use GPIB command to set nd measure the parameters.
Joly
Joe
Using Ver. 8.0
Message 1 of 8
(6,244 Views)
There's a driver for it on the Instrument Driver Network.
Message 2 of 8
(6,241 Views)
but that dosen't have any driver in that link pls check.....
Joe
Using Ver. 8.0
Message 3 of 8
(6,203 Views)
Yes it does. Did you try to look through the manufacturer list over on the right side of the page or try the Browse Drivers link at the top?
Message 4 of 8
(6,201 Views)
Here is the link to the page with all of the Elgar models.  Use the link that Dennis provided in the future to search for your other instrument models in the future.
Cheers,
NathanT
Message 5 of 8
(6,194 Views)
Hey Joly,
The initial Link Dennis sent leads you to the main page. You can click on browse, and then if you search for the model of your instrument, you'll see a list of what drivers we have for the list. I saw the link by Nathan may be broken, so I went and updated it.
Nick D.
Message 6 of 8
(6,180 Views)
Dear all,
This is the link for elgar where as no drivers available inside this Link. Pls check and clear me.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E92DB659CE034080020E748...
Joe
Using Ver. 8.0
Message 7 of 8
(6,175 Views)
Thanks i got it ...!!!
Joe
Using Ver. 8.0
Message 8 of 8
(6,174 Views)
