Errors -1074000000 and -1073807339 with Tektronix 7000 Series Instrument Driver Example Programs
yes I have a wrong programming organisation, I am going to correct that.
Thank you
Message 21 of 23
(2,089 Views)
hello
I run into same problem and solved it though not sure why it actually works. I inserted a "VISA read STB" after each "VISA write" (see picture). I believe it gives some more time for scope to prepare response. anyway it seems to work. I had similar issue in "Error Query.vi" (part of "Tektronix DPO MSO 2000 4000 Series.lvlib") and similar solution fixed the issue i.e. I entered a "VISA read STB" after each "VISA write"
Message 23 of 23
(1,379 Views)
