Example programs for DSO1000 PnP drivers do not work at all with DSO1022A
I am having problems with the DSO1000 PnP driver when used with the DSO1022A digitizing oscilloscope from Agilent.  The example programs do not work.  They all time out when transferring data with the exception of the "Agilent DSO1000 Series Transfer Current Waveform" example.  My scope is correctly recognized as a USBTMC device and I can communicate via VISA but the driver is all but useless.
The ag1000ni IVI driver also fails to work correctly in LabVIEW Signal Express.
Any help would be greatly appreciated.
Best Regards,
Nzah
Message 1 of 26
(5,726 Views)
Can you please indicate what version of firmware your scope has?
Message 2 of 26
(5,704 Views)
I updated the firmware with the latest one from the Agilent website several days ago.  Firmware version is: 011.04.00.04.06
nzah
Message 3 of 26
(5,698 Views)
We were able to reproduce the issue.  We have only seen the issue with the latest version of the firmware (011.04.00.04.06) and we will be working with Agilent to try to resolve the issue.
Message 4 of 26
(5,669 Views)
I have actually observed the same issue with the ...04 version of firmware as well.
Best,
nzah
Message 5 of 26
(5,667 Views)
       I have attached an updated version of the instrument driver.  Please give it a try and let us know if you still see any problems.
Cheers,
NathanT
Message 6 of 26
(5,620 Views)
Hi Nathan
pleas modify the version in the html also, or when informed it is a correct version.
greetings from the Netherlands
Message 7 of 26
(5,616 Views)
Hello Albert,
        Thanks for noticing that.  We will certainly update the documented version of the driver in the readme file and other locations.  Initial customer testing is indicating that the updates are working.  I look forward to hearing from more people testing the updated driver.
Thank you,
NathanT
Message 8 of 26
(5,599 Views)
Hi Dear
I try to use attached examples that you send, but while I try run them some sub.vi can not be found or loaded by Labview, and Labview asked me to find them, could you help me how I do come up with this problem?
Masih
Message 9 of 26
(5,192 Views)
There is nothing missing. Since you have not provided the necessary information as to what VIs you are being prompted to find, I can only speculate that you installed the driver in the wrong location. Under instr.lib, you should have a folder called 'Agilent DSO1000 Series' with the lvlib, lvproj, and the public, priveate, and examples folders.
Message 10 of 26
(5,190 Views)
