Example programs for DSO1000 PnP drivers do not work at all with DSO1022A
As you mentioned, I install Agillent DSO 1000 folder in wrong path. Now it works correctly.
Thank you very much
Message 11 of 26
(2,336 Views)
Hi Albert
I use the new version that you have uploaded but the captured signal from DSO 1022a, is completely distorted compare with the wave which is show on the DSO screen. What do you think how to get clear figure from DSO?
Best Regards
Masih
Message 12 of 26
(2,327 Views)
Hi Albert
Best Regards
Masih
Message 13 of 26
(2,328 Views)
Hi
I did not upload the driver Nathan Tacha did and as from about that day on it could also be found on the NI Website
select http://www.ni.com/devzone/idnet/
or click on the 3th tab of ni.com and in the left row bottom of the first links select Instrument Driver Network
and there type Agilent DSO1022 in the search field
or even better in LabVIEW select Help/Find Instrument Drivers
log in and search for Agilent and DSO1022 and it will be immediately be installed and usable.
greetings from the Netherlands
Message 14 of 26
(2,324 Views)
Hi Albert
Finally,I can capture data from DSO1022a but you can see on attached images, the wave captured by labview is distorted compare with the real signal the can be observed on the DSO screen.Could you help me how I can to get clear signal?( I also attached the labview file that I used)
Message 15 of 26
(2,318 Views)
Hi Albert
Sorry, At my last post, I couldn't attach my images.
Message 16 of 26
(2,316 Views)
Hi Complex,
What channels are you referancing? Can you double check and make sure that you are referancing the same channels.
Perry S.
Message 17 of 26
(2,290 Views)
Hi Albert
I connect my function generator to the channel 1 of "DSO1022a" and in Labview, I select channel 1. On DSO1022a screen I get clear SIN wave but on Labview screen I get distorted SIN wave. One more question, Is it possible to capture data from DSO1022a using  Labview Signal express 2010?
Message 18 of 26
(2,278 Views)
Hi Complex,
There is a step in Signal express that allows you to run LabVIEW VIs. You can give that a try. What type of connection do you have for your device? Is it Serial or GPIB?
Perry S.
Message 19 of 26
(2,267 Views)
Hi
it's GPIB.
Message 20 of 26
(2,260 Views)
