Facing problem in NI VISA.
I am using VISA to communicate with the parallel port but when i run my program it gives the following error
"Error -1073807339 occurred at VISA Write in" and the given possible reason is "VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed." Please help me what should i do to correctly communicate with the parallel port.
Husnain Taseer
(3,254 Views)
Did you ground the necessary pins? See this document for details: http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB
(3,248 Views)
Accepted by Hasni
Thanks alot...
Problem has been solved after setting PIN 11 and 12 to ground.
(3,234 Views)
