Fixing connectivity issues on the SR510 over GPIB
Contrariwise gpib is working only without rs232 echo.
But you have right, I have another problems.
Message 31 of 32
(1,497 Views)
I have similar problems with SR510 connected with GPIB-USB-HS.
I found out that using command W n (n can be from 1 to 255) (by default set W 6 when turn on) one can slow down sending (reading) commands.  The W 20 works for me.  Problem was to send initial command but I read the discussion before and it works now.
Message 32 of 32
(740 Views)
