Frankonia FC 02 antenna mast and turntable controller
Have some one had deal with FRANKONIA turntables and anenna masts? I've got SCPI commands in devices manual. I've tried to controll these devices using visa but unsucsesfully. They are not moving. I used the same code to controll analiser and it works (ofcourse i changed commands and adresses). If someone have some code example..... help me.....
Message 1 of 15
(7,159 Views)
Dear ku ku,
Is your connection serial?
Perhaps you should try LabVIEW shipping examples.  A good example would be Basic Serial Read Write. vi
Sammy Z.
Message 2 of 15
(7,125 Views)
I'm using GPIB interface. I solved my problem in oposite direction. I instaled  manufacturers given turntable softvare and throught NI SPY  registrated what is happening on GPIB buss when I'm controlling turntable. After that I made vi that imitates the registrated commands on buss....
Thank you !!!
Message 3 of 15
(7,110 Views)
I am trying to write a program for the turner.
I want to turn it for 1 degree each 1 second.
Can I write it in .net environment ?
Message 4 of 15
(6,408 Views)
As long as the instrument supports this functionality, you can write the program in any language supported by NI-VISA. There are .NET examples installed with the driver. I would suggest that you first test the SCPI commands in MAX before writing any code.
Message 5 of 15
(6,404 Views)
Thanks Denis,
I can't find any .net examples. can you please put a link ?
How  can I "test the SCPI commands in MAX" ?
I have tested the commands in  Basic Serial Read Write. vi
Thanks a lot.
Ivgeni.
Message 6 of 15
(6,400 Views)
Message 7 of 15
(6,394 Views)
I see in the links this path :
program files\national instruments\measurementstudio2005\dotnet\examples
I don't have it, so try to install NIVISA541full.
it writes me
Measurement Studio Visual C++ 2008 support not present
The NI-VISA Measurement Studio for Visual C++ 2008 Support feature requires you to install Measurement Studio Visual C++ 2008 Support from the Measurement Studio installer.
and the link for downloading it is not working
http://www.ni.com/download/measurement-studio-visual-c-support-8.6/1182/en/
what can I do ?
Ivgeni
Message 8 of 15
(6,375 Views)
Are you actually going to use Measurement Studio or just Visual Studio?
Message 9 of 15
(6,367 Views)
just visual studio
Message 10 of 15
(6,364 Views)
