GPIBについて
PCI-GPIBボードを使用いている同環境で、USB-GPIBを使用しても
同じ動作しますか?
(3,921 Views)
This is an English forum, and therefore I will answer based on what google translated:
When using USB-GPIB in the same environment using PCI-GPIB board
Does the same work?
In short, yes. There are some performance differences, but I would not expect them to be significant for a common application. Nevertheless, I recommend you take a look at the specifications for the devices you are considering to ensure they work for your application: NI GPIB Hardware Installation and Specifications
(3,482 Views)
