GPIB-Ermme
Hi ,
I have a instrument(Ermme MF 28) with a module gpib (GPIB-232CT-A)and i want to know what is the command for the identification of this instrument
The commmand "*idn?" doesn't work.
(3,005 Views)
I can't help with specifics but the manufacturer should be able to provide a programming manual. I did find their web site but couldn't find a link to anything on-line. Most serial instruments, I've found, do not comply with 488.2 so I wouldn't expect the *IDN? command to work. Even if it did, you would still need the manual to do any programatic control of it.
(2,998 Views)
