GPIB-USB-HS+ sanitization procedure
I have searched for an answer for this and cannot find anything. Does the GPIB-USB-HS+ adapter have memory that would require a sanitization procedure. I need this information for a hardware baseline on a classified test stand.
(3,685 Views)
Might be easier if you were to list the manufacturer and their device information.  Also, we have seen a number of counterfeit NI ones listed in this community that do not work properly and have the wrong P/N's or S/N's.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,649 Views)
Accepted by topic author Myxtyr
NI typically provides information about memories in a "Letter of Volatility"
The one for the HS+ is here http://www.ni.com/pdf/manuals/374618a.pdf
(3,643 Views)
Thank you James-G that is what I was looking for
(3,638 Views)
Please mark James-G reply as the solution to this forum question.
Warm regards,
Gustave
(3,635 Views)
