GPIB-USB-HS with RHEL/Centos 6 or RHEL/Centos 7 Linux Driver
Amazed how stagnant information is on this site....
What is the latest GPIB driver or beta driver that can support 64 bit RHEL6/7
(3,538 Views)
The driver you will need is NI-488.2 compatible versions for you hardware and OS can be found by consulting the pages below.
NI-488.2 Operating Systems Support
(3,495 Views)
Run-around.        Date: 7/19/2019
The answer is NO support for GPIB-USB-HS with RHEL6 or RHEL7 Linux.
Supported GPIB Interfaces
PCI-GPIB
PCI-GPIB/LP
NI PCIe-GPIB
PCI-8212*
PCI-8232
PXI-GPIB
PXI-8212*
PXI-8232
GPIB-ENET/100*
GPIB-ENET/1000
(3,475 Views)
NI,
What is NI's position in supporting NI-GPIB-USB under newer versions of RHEL?
Is the NI-GPIB-USB EOL???
Thanx.
-csk
(3,262 Views)
Newcomer here, and reading the posts here pretty much says NO GPIB-USB-Support.
So, having to bite the bullet again, which PCI card is recommended for Ubuntu 22.04?
(1,000 Views)
