HP 70950a OSA
Hi Karin,
What do you have for development tools?
LabVIEW or Visual Basic would be the easiest way to go
Curt
Message 11 of 16
(1,253 Views)
Hi Curt
I have LabVIEW.
Best,
Karin.
Message 12 of 16
(1,247 Views)
Can I get a hint to how to do this in LabVIEW? I must admit that I haven't worked with it before.
Best,
Karin.
Message 13 of 16
(1,232 Views)
Basicqlly each of the OUTPUT statements would be a VISA Write function and the ENTER is a VISA Read. The output of the VISA Read is a string that would be need to be converted but how would depend on the type of data you are reading (i.e. wavefolrm array, scalar, etc.). I would suggest the basic LabVIEW tutorial.
Message 14 of 16
(1,226 Views)
Hi Karin,
You should be able to find a sample gpib VI at
C:\Program Files\National Instruments\LabVIEW #.#\examples\instr\smplgpib.llb\LabVIEW - GPIB.vi
Good luck with your task
Curt
Message 15 of 16
(1,211 Views)
it is quite simple: you need first to open the communication with the module in the OSA, not with the OSA itself.
Then it is just a matter of WRITE and READ commands.
In the attached vi I acquire the spectrum, and decided which scale (linear or dB) to use.
Message 16 of 16
(1,186 Views)
