01-06-2012 08:06 AM
Hi Karin,
What do you have for development tools?
LabVIEW or Visual Basic would be the easiest way to go
Curt
01-06-2012 10:20 AM
Hi Curt
I have LabVIEW.
Best,
Karin.
01-08-2012 09:36 AM
Can I get a hint to how to do this in LabVIEW? I must admit that I haven't worked with it before.
Best,
Karin.
01-08-2012
11:24 AM
- last edited on
04-11-2025
11:07 AM
by
Content Cleaner
Basicqlly each of the OUTPUT statements would be a VISA Write function and the ENTER is a VISA Read. The output of the VISA Read is a string that would be need to be converted but how would depend on the type of data you are reading (i.e. wavefolrm array, scalar, etc.). I would suggest the basic LabVIEW tutorial.
01-09-2012 06:38 AM
Hi Karin,
You should be able to find a sample gpib VI at
C:\Program Files\National Instruments\LabVIEW #.#\examples\instr\smplgpib.llb\LabVIEW - GPIB.vi
Good luck with your task
Curt
04-12-2012 04:40 PM
it is quite simple: you need first to open the communication with the module in the OSA, not with the OSA itself.
Then it is just a matter of WRITE and READ commands.
In the attached vi I acquire the spectrum, and decided which scale (linear or dB) to use.
