HP428XA Close.vi
I am a new Labview user.
We use labview to control LCR meter.
It was working fine before.
Recently, when I opened the file, it started to load the file and can't find "HP428XA Close. vi".
I tried to search in my hard drive but couldn't find it.
Could you give me some suggestion to solve this problem?
(4,944 Views)
Could you provide more information on what version of software and drivers you have? I have a feeling that the file that is being reported as missing has to do with the device driver. What device are are you using?
Thanks!
(4,919 Views)
Sounds like you need to install the LabVIEW driver for your LCR meter.  Try this: Agilent 428X Series Meter
(4,914 Views)
Dear Riccardo,
We are using Labview 20th Anniversary edition (8.2.1).
The device we tried to control is a HP precision LCT meter 4284A.
Thanks for your reply.
(4,909 Views)
Someone renamed or deleted the function in the lvlib so just reinstall it. You should find the project in your instr.lib folder.
(4,900 Views)
