Having problems taking usb scanned data input into my vi along with gpib instrument data to save to file.
Gentlemen,
I have been trying to integrate the WT500 via gpib; taking instrument data and saving that to a spreadsheet file with headers. Because I have a different DUT each time I test I elected to be able to read the bar code into the vi (beginning of each row) below the main header.  I can't make that happen.  The scanned text comes in via usb fine, but it won't behave after that.  It appears it needs to be a string, otherwise it filters out all the alphabet characters and leaves numbers only.  That's a problem where I need both because I don't know how to combine those two in a array to be saved as shown as attached..  Further when I close this vi it won't save the headers assignments.  I have to retype them all over again.
Any suggestions would be appreciated.
Eric
(2,961 Views)
What about something like this for formatting?  For your enumeration options, you can pass in the property node strings[] instead if you do not wish to change them to an array of strings.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,927 Views)
I'll let you know if it works.
Thank you very much!
(2,924 Views)
