How can I send a command on GPIB-Bus from Teststand?
I have the following problem:
I want to send from teststand via a NI GPIB-Interface a command on the GPIB bus.
how can I do this without a IVI driver?
thank you
regards samuel
(3,418 Views)
For example you can write a code module in Labwindows/CVI, which uses the GPIB library
(3,407 Views)
Also, you can use following step type. Hopefully, this helps you.
NI TestStand 3.1
"Only a life lived in the service to others is worth living..." - Albert Einstein
(3,404 Views)
