11-06-2017 04:06 AM
HI NI,
I am working with TM4C1294xl evaluation board http://www.ti.com/tool/EK-TM4C1294XL, trying to communicate the test equipments with GPIB interface. I can't use any OS for this project due to the timing constrain. The simple way to talk to the device is through NI GPIB-USB-HS cable.
TM4C1294xl is programed with tivaware (bare-metal SDK package from manufacturer). Right now I have configured the usb port as Host CDC, and able to send / receive data from usb serial device through usb Bulk in/out pipes respectively.
I am wondering whether this solution is feasible and how TM4C1294xl can communicate to GPIB-USB-HS via its USB port as generic bulk or any other type of device?
Please advise, thanks in advance
Mike
11-06-2017 08:09 AM
You can't.
11-06-2017 08:20 AM
Hi njacacia,
Thanks for your fast reply. If GPIB-USB-HS doesn't work for me, is there any other alternative solution you might think of? I just want to use ARM based MCU to talk to GPIB device without OS(Kernel).
Best
Mike
11-06-2017 08:25 AM
Perhaps you could write your own driver.
I have no idea.
11-06-2017 08:33 AM
That's exactly what I plan to do. But I need some kind of reference document/manual for GPIB-USB-HS about the communication protocol. I would really appreciate if you or any colleague in NI could provide any kind of help.
11-06-2017 08:37 AM
The manual for the GPIB-USB-HS is on ni.com
You'll have to talk to NI if you want something else.
11-06-2017 08:52 AM
The online manuals related to GPIB-USB-HS is just OS oriented installation guide with driver provided by NI. I can't find much useful info about the communication protocol between OS and GPIB-USB-HS.
Do you know exactly which department or NI expert I should talk to in order to acquire the info I need to write my own driver for MCU?
Thanks in advance
11-06-2017 08:53 AM
Thanks in advance
No idea. I have never wanted or needed to do what you want to do.
11-06-2017 09:30 AM
In windows OS, did anyone try to use generic bulk driver with correct PID/VID from NI to talk to GPIB-USB-HS?
11-06-2017 10:01 AM - edited 11-06-2017 10:02 AM
You do realize that the GPIB-US-HS is not an instrument, right? It allows one to "talk" to an instrument.
