How can we configure the reading cycles of the serial port ?
Hi all,
Refer to my previous post "Continuous read and save date in a specified time with serial port" now my problem becomes how can I configure the reading cycles of the VISA Read ?
My sensor device has a sampling cycles is 100 usec (10kHz) (a measurement data has 7bytes, ex:+1.125CR+3.165... CR is inserted between measurement), however the transfering cycle of the device to PC via serial port is 5 msec/character (bytes). Then the transfering cycle of a measuremet is 35 msec (sampling rate 28.6Hz).
I tried to change different baud rates but have no change for the sampling rate of the record data. It looks like serial port is not a good choice for applications requiring high sampling rate. Or is there any other hints that somebody could share with me ?
Looking for your advices, thank you so much.
(3,077 Views)
If the vendor says that continuous transmission results in 5-10 msec per character, then that might be what you have to live with. Have you contacted them to see if there is a faster mode? Perhaps reading as binary instead of ASCII?
And yes, serial is the slowest form of instrument communication.
(3,073 Views)
Hi Knutson,
Thank you for all your suggestions.
(3,059 Views)
