Trouble for Centos5.6 install VISA5.0
It displays as following:
[root@localhost nivisa]# ./INSTALL
  NI-VISA for Linux
     version 5.0.0f1 for Linux
National Instruments products support the following Linux distributions:
   openSUSE
   Red Hat Enterprise Linux Desktop + Workstation
Refer to README.txt for the latest information at the time of release.
Refer to www.ni.com/linux for the most recent information about Linux
support at National Instruments.
Continue? [Yn] y
Checking required install tools...
Checking installer tool versions...
dpkg       Not found in current path
rpm        4.4.2.3 can be used with a default installation path
tar        1.15.1
Checking dependencies...
glibc      2.5
Unpacking install files to /tmp/nivisa-5.0.0f1.install...
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to    *
* compile the currently running kernel.  This can cause unpredictable         *
* behavior in kernel drivers and should be fixed.                             *
* gcc version: gcc 版本 4.1.2 20080704 (Red Hat 4.1.2-50)                                                          *
* kernel compiled with: 4.1.2                                                 *
Installer is aborted.
did anyone meet such problem? ask for help.
(2,968 Views)
NI only supports limited version of Linux OS. Please refer to this link:
http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661?OpenDocument
(2,961 Views)
