04-25-2011 04:12 AM
It displays as following:
[root@localhost nivisa]# ./INSTALL
NI-VISA for Linux
version 5.0.0f1 for Linux
National Instruments products support the following Linux distributions:
openSUSE
Red Hat Enterprise Linux Desktop + Workstation
Refer to README.txt for the latest information at the time of release.
Refer to www.ni.com/linux for the most recent information about Linux
support at National Instruments.
Continue? [Yn] y
Checking required install tools...
Checking installer tool versions...
dpkg Not found in current path
rpm 4.4.2.3 can be used with a default installation path
tar 1.15.1
Checking dependencies...
glibc 2.5
Unpacking install files to /tmp/nivisa-5.0.0f1.install...
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to *
* compile the currently running kernel. This can cause unpredictable *
* behavior in kernel drivers and should be fixed. *
* gcc version: gcc 版本 4.1.2 20080704 (Red Hat 4.1.2-50) *
* kernel compiled with: 4.1.2 *
Installer is aborted.
did anyone meet such problem? ask for help.
04-26-2011 01:59 AM
NI only supports limited version of Linux OS. Please refer to this link:
http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661?OpenDocument
