How can we make communication with RS-232 port's data on visual basic?
Hello
I am going to test my serial device with programmed in visual basic software.
I am learnig it, so please help me to do programing.
"SB02"
(3,760 Views)
@Bhadresh wrote:
Hello
Visual Basic 6 or Visual Basic.NET
makes a difference
either way, Google is your friend
(3,748 Views)
I think your best bet is to use use a serial session in NI-Visa and .NET. I've used Microsoft's Serial class before with instrumentation and have had some problems.
Imports NationalInstruments.VisaNS 'set a reference to visa first
Public Class Form1
    Dim meter As VisaNS.SerialSession
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Try
            meter = New SerialSession("ASRL1::INSTR") 'comport 1
            meter.BaudRate = 9600
            meter.DataBits = 8
            meter.StopBits = StopBitType.Two
            meter.Parity = Parity.None
            meter.FlowControl = FlowControlTypes.DtrDsr
            meter.Timeout = 5000
            meter.Write("CONF:VOLT:DC")
            meter.Write("VOLT:DC:RANG:AUTO ON")
            meter.Write(":READ?")
            TextBox1.Text = meter.ReadString()
        Catch ex As Exception
        End Try
    End Sub
End Class
Curt
(3,734 Views)
Keep in mind that there are fees for NI-VISA if you are not using any NI hardware or software.
(3,729 Views)
