How do I configure a serial instrument using INI file?
Kindly send an example vi.
skhanna
(3,305 Views)
Storing configuration information in an INI is not related to configuring serial instruments (although you can store configuration information in an INI file). I recommend searching the LabVIEW examples on how to use INI files and serial communication.
LabVIEW/examples/file/config/llb
LabVIEW/examples/instr/smplserl.llb
(3,305 Views)
