How do I set the IP address of my GPIB-ENET 100 device in Windows XP environment?
I have a new GPIB-ENET/100 device that I am trying to get running with my test setup.  All of the older devices like this that I have, have the IP address set in them to 192.168.1.20.  I want to set the new device up like this as well, buty can't find a way to do it so far.  The knowledge base articles I have read said that there was currently no way to do this in Windows XP, but you could use this Assign IP utility in Windows 3.1 or Windows 2000/NT.  We haven't had one of those machines in our lab for quite some time, so I really can't believe that this is still true.  Can someone point me in the right direction of how to set this IP address so I can use the equipment with my software without having to make changes every time the DHCP gives it a diferent address??
Doug Borders
(3,505 Views)
Hi Doug,
Please take a look at the following articles which addresses setting a static IP address for the GPIB ENET/100.
KnowledgeBase 3E3ALM4B: Setting Up the GPIB-ENET/100
KnowledgeBase 3E5H8OMQ: ENET/100: Why Does the GPIB Hardware Wizard Fail While Sequentially Verifyin...
Hope this helps,
John M
(3,462 Views)
Doug,
To help clear up some of the confusion, the documents you saw that are referring to Windows 3.1/2000/NT are not for the GPIB-ENET/100. These are referring to the GPIB-ENET, which was the predecessor to the GPIB-ENET/100, and has not been available for years.
-Jason S.
(3,456 Views)
