How to connect two GPIB?
   I use Agilent 4352b(a Signal Analyze) and 8664A(a Signal generator).4352b connect  8664A through a GPIB.
  Now I want to connect 4352b through Keysight 82357B (a GPIBtoUSB converter) .
  I search out some GPIB port :
  GPIB0::16::INSTR
  GPIB0::17::0::IINSTR
 GPIB0::17::1::IINSTR
 GPIB0::17::13::IINSTR
  GPIB0::17::14::IINSTR
  GPIB0::17::15::IINSTR
  GPIB0::17::16::IINSTR
   but they all can't connect !
  why?
(4,825 Views)
Why do you want a second GPIB interface. One GPIB interface can handle up to 15 instruments but two should always work. Just use a GPIB cable to connect the two instruments and you are done.
greetings from the Netherlands
(4,819 Views)
thank you
I think you may have some misunderstandings, I use 2 instruments instead of two interfaces/ports/GPIB .
Computer——Signal Analyze ——Signal generator ,They are connected to each other.
Signal Analyze ——Signal generator,Analyze must connect to Generator to work, and they're already connected(This is the case at the factory).
Now I want to connected Signal Analyze.
(4,809 Views)
Accepted by topic author xiaochouyu
Is the Generator or the Analyzer set up as the GPIB master?  You can only have 1 master on a bus.  Typically, if there is a "master" GPIB connection on an instrument, there is a second GPIB interface in order to accept commands from a PC.
(4,801 Views)
thank you
It seems that I can't connect to Analyzer. Because it's going to control Generator
(4,799 Views)
