How to determine the reference level crossing to be counted for measurement
Measuring Reference-Level Crossings - NI
I don't understand why the next second-level crossing point after the first crosspoint isn't counted
I think the signal goes outside the window and then crosses the reference level
Could someone clarify this for me?
(481 Views)
Accepted by topic author usan1
Missing information is that the hysteresis is symmetrical around the reference level (two dotted lines above and below)
Count a point if,
  • fall down crossing upper threshold and reference
  • rises up crossing lower threshold and reference
  • switch between fall down or rise up logic only if the signal crossed the threshold
The middle peak points is not counted because the signal did not cross the lower threshold after the first sample.
Santhosh
Soliton Technologies
(445 Views)
