How to install NI-VISA 4.4.0 kernel modules under Gentoo ?
I am trying to install the Ni-Visa  but the modules fail to compile into my kernel.....
I am using  2.6.26  kernel Version.
Can somebody help me a bit ?
the installation output  is here:
Configuring for linux kernel version 2.6.26-gentoo-r1.
********************************* NOTE *********************************
Using kernel headers found in /lib/modules/2.6.26-gentoo-r1/source.
If this does not correspond to the location of the 2.6.26-gentoo-r1 headers,
then define KERNELHEADERS in your environment to point to the location
of the kernel headers, define KERNELTARGET as the version of the
kernel for which to compile, and then rerun ./configure.
Kernel has reparent_to_init(): no
Number of arguments for do_munmap(): 3
pte_offset function: pte_offset_kernel()
Levels in page table: 4
Kernel has remap_pfn_range: yes
USB altsetting name: cur_altsetting
Kernel has usb_get_intf(): yes
Kernel has intf_cache member in usb_host_config: yes
Kernel has ep[] members in usb_device: yes
Kernel exports usb_set_configuration(): no
Units of USB_CTRL_GET_TIMEOUT: msec
Kernel has owner member in usb_driver: no
Kernel has put_page_testzero(): yes
Kernel has mutex method: yes
Kernel has kthread: yes
Kernel has config.h: no
Kernel has ioctl32.h: no
IRQ handlers have pt_regs: no
Kernel has work_struct and delayed_work: yes
Storing configuration in Makefile.in
If the values stored are incorrect they can be changed before running make.
Uninstalling NI-KAL (nikal): done
/bin/rm -rf objects
Updating NI-KAL:
 NI-KAL update failed.
/bin/cp nikal.c objects/nikal.c
/bin/cp nikal.h objects/nikal.h
make -C /lib/modules/2.6.26-gentoo-r1/source SUBDIRS=/usr/local/natinst/nikal/src/objects modules
make[1]: Entering directory `/usr/src/linux-2.6.26-gentoo-r1'
  CC [M]  /usr/local/natinst/nikal/src/objects/nikal.o
/usr/local/natinst/nikal/src/objects/nikal.c:447: error: unknown field 'nopage' specified in initializer
/usr/local/natinst/nikal/src/objects/nikal.c:447: warning: initialization from incompatible pointer type
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_destroySemaphore':
/usr/local/natinst/nikal/src/objects/nikal.c:2355: error: 'nLinux_semaphore' has no member named 'sleepers'
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_releaseSemaphore':
/usr/local/natinst/nikal/src/objects/nikal.c:2420: error: request for member 'counter' in something not a structure or union
make[2]: *** [/usr/local/natinst/nikal/src/objects/nikal.o] Error 1
make[1]: *** [_module_/usr/local/natinst/nikal/src/objects] Error 2
make[1]: Leaving directory `/usr/src/linux-2.6.26-gentoo-r1'
make: *** [objects/nikal.ko] Error 2
ERROR: make of nikal kernel module failed, not installing kernel module.
   updateNIDrivers should be called again after fixing the problem.
   Logging failure...
   Include the file /tmp/niSystemReport.out.gz when contacting
   National Instruments for support.
 and the niSystemReport :
Ελευθερία σημαίνει ότι μαθαίνεις να έχεις απαιτήσεις μόνο από τον εαυτό σου, όχι από τη ζωή ή τους άλλους
Message 1 of 25
(7,898 Views)
modules compiles fine with kernels (gentoo-sources) :
  • 2.6.22
  • 2.6.24
  • 2.6.25
with my kernel configuration
Message 2 of 25
(7,872 Views)
NI VISA 4.4 for Linux requires one of the following distributions : Mandriva 2008, Mandriva 2007, openSUSE 10.3, openSUSE 10.2, Red Hat Enterprise Linux Desktop, Red Hat Enterprise Linux WS 4. This info can be found in the NI VISA 4.4.0 readme file. I do not know why other kernals compile. I will try and find a work-around for you.
Message 3 of 25
(7,845 Views)
It only works with kernel 2.6.22 and below.
Message 4 of 25
(7,760 Views)
We just released NI-KAL 1.9 which should compile on kernels up to 2.6.27.  We also just created a new Linux Users community where we can post announcements of new releases, and everyone can create tutorials and content on the wiki-like interface.
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
Message 5 of 25
(7,497 Views)
It failed compiling on my 2.6.25 gentoo kernel. I've attached the system report as well.
make -C /lib/modules/2.6.25-gentoo-r7/source SUBDIRS=/usr/natinst/nikal/src/objects modules
make[1]: Entering directory `/usr/src/linux-2.6.25-gentoo-r7'
  CC [M]  /usr/natinst/nikal/src/objects/nikal.o
  Building modules, stage 2.
  MODPOST 1 modules
WARNING: "init_mm" [/usr/natinst/nikal/src/objects/nikal.ko] undefined!
  CC      /usr/natinst/nikal/src/objects/nikal.mod.o
  LD [M]  /usr/natinst/nikal/src/objects/nikal.ko
make[1]: Leaving directory `/usr/src/linux-2.6.25-gentoo-r7'
Installing NI-KAL (nikal): Starting NI-KAL failed!
make: *** [install] Error 1
Message 6 of 25
(7,482 Views)
Um, have you applied additional kernel patches to your kernel?  I just took a peek in on my gentoo system where I still have 2.6.25-gentoo-r6 hanging around and init_mm is still defined and exported in:
arch/x86/kernel/init_task.c
So unless you have applied a patch that unexports init_mm I'm not sure why it is failing.  P.S. your niSystemReport shows you are still using NI-KAL 1.8 instead of 1.9, but it shouldn't matter unless you want to run newer kernels.
Shawn Bohrer
Message 7 of 25
(7,474 Views)
I'm using the default gentoo-sources. I have that file too and init_mm is defined  there:
struct mm_struct init_mm = INIT_MM(init_mm);
I'm not sure why it's complaining.
PS. is ni-kal updated for newer kernels as well?
Message 8 of 25
(7,469 Views)
does your file have:
EXPORT_UNUSED_SYMBOL(init_mm); /* will be removed in 2.6.26 */
It is actually the EXPORT_UNUSED_SYMBOL(init_mm) part that is important as that lets external kernel modules see the symbol.
NI-KAL 1.9 should compile against kernels 2.6.27 and older.
Shawn Bohrer
Message 9 of 25
(7,467 Views)
Kernel headers are OK. I've found that the INSTALL script is not actually doing anything! Reading the INSTALL script it seems like I need to have either dpkg or rpm. is that correct?
Message 10 of 25
(7,462 Views)
