How to install NI-VISA 4.4.0 kernel modules under Gentoo ?
Untarred nikal-1.9.0f0.tar.gz in the iso. That gave a "bin" and "rpms" directories. Converted nikali-1.9.0-f0.noarch.rpm  to tar using rpm2tar and expanded it to the right directory which was /usr/local/natinst/nikal. Added the nikal directory string " /usr/local/natinst/nikal" to /usr/local/natinst/nikal/etc/nikal.dir. Now updateNIDrivers gives me the same error as before!
Message 11 of 25
(3,412 Views)
It looks like you need:
CONFIG_UNUSED_SYMBOLS=y
In your kernel config.
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
Message 12 of 25
(3,406 Views)
Awesome! that worked! hopefully with this version fixes my Tektronix 2024B  USB problems.
Message 13 of 25
(3,400 Views)
i am trying to build pikal......but the module instalation fail for kernel 2.6.27.....with enable option CONFIG_UNUSED_SYMBOLS=y
Ελευθερία σημαίνει ότι μαθαίνεις να έχεις απαιτήσεις μόνο από τον εαυτό σου, όχι από τη ζωή ή τους άλλους
Message 14 of 25
(3,128 Views)
In general if NI-KAL fails to compile you should always try the latest version of NI-KAL.  Currently the latest version is NI-KAL 1.9.
Shawn Bohrer
Message 15 of 25
(3,113 Views)
i tried the latest NIKAL but the same errors !!!!
Message 16 of 25
(3,098 Views)
i am tring with different setting to compile my kernel....but the some errors
Message 17 of 25
(3,091 Views)
well it seams that the problem isnt the kernel....but the installations scripts from the visa-4.5....i extract the nivisa-4.5.0f0.tar.gz and i installed the packages with the rpm command....
the modules failed because the installation script doesnt update the visa drivers...
Message Edited by Sak1s on 03-15-2009 10:45 AM
Message 18 of 25
(3,074 Views)
If you are getting the same errors then you have not installed NI-KAL 1.9.  Looking at the niSystemReport files you attached confirms this.  The first line in the niSystemReport output gives the version of niSystemReport which is the same as NI-KAL since they are shipped together.  Yours still says 1.8.0f0, which would explain why NI-KAL will not compile against your kernel.  How are you trying to install NI-KAL 1.9?
Shawn Bohrer
Message 19 of 25
(3,045 Views)
Dear Shawn B.  i dont know the reason....i was running the istalation script from the NIKAL19.iso and also the visa-4.5.iso .Now i install the new visa drivers by extracting and installing with the rpm command,i think that the installation script not actually doing anything,and then calls the updatevidrivers.sh and trying to update my modules with the previous version.
Message 20 of 25
(3,041 Views)
