How to install NI-VISA 4.4.0 kernel modules under Gentoo ?
So did you get everything installed and working?  If you just unpacked the rpms and installed them manually then it is possible that some configuration steps were not run.  So I'm guessing NI-VISA still does not work.
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
Message 21 of 25
(2,246 Views)
well the visa drivers and the visaconf seams to work fine.....but what is the right rpm installation order for the runtime visa ???
Ελευθερία σημαίνει ότι μαθαίνεις να έχεις απαιτήσεις μόνο από τον εαυτό σου, όχι από τη ζωή ή τους άλλους
Message 22 of 25
(2,232 Views)
I'm not sure I understand the question.  If you want to just install the NI-VISA runtime you can download the separate installer here.  Note that installing the full version of NI-VISA also installs the runtime.  It is recommended that you run the INSTALL scripts provided with both NI-VISA and the runtime, since it will perform extra steps needed to configure the kernel modules for your system.  If running the INSTALL scripts doesn't work I would be interested in seeing the output from the scripts so that we can improve future versions.
Shawn Bohrer
Message 23 of 25
(2,228 Views)
sorry for my poor english.....well i mean the dependencies for the nikal modules..... if i want to install the only the nikal driver and the visaconf to my machine....witch rpms i have to install manually ?
Message 24 of 25
(2,221 Views)
Unfortunately that is a hard question to answer.  All of the rpms are needed for some part of NI-VISA to function or they wouldn't be included.  If you install all of the rpms from the NI-VISA Runtime package that will give you the bare minimum to make NI-VISA function, but it won't provide the developer tools like visaconf.  I'm not a visa expert, but looking at the rpms in the NI-VISA 4.5 package I would guess that the nivisa-config-4.5.0-f0.i386.rpm, and nicvirte-8.0-7.i386.rpm would provide visaconf.  You may also need nivisa-devel-4.5.0-f0.i386.rpm but I'm not sure.
Shawn Bohrer
Message 25 of 25
(2,212 Views)
