 bratidiana
			bratidiana
			07-20-2012 09:16 AM
Hi, I'm new in this field and I'm having a problem in acquiring data from a RS232 port. Actually, I'm not sure if it is possible to do it.
What I would like to do, is to read the voltage difference between two pins of the port. This is because I want to measure temperature (and save the data) in a very simple way. I have 6 thermocouples and I was thinking of welding them to different pins of the RS232 and acquiring the analog signals in mV with the computer. Then, I would use a thermometer to calibrate the values.
Is it possible to do this? How? I've been looking a lot but I cannot find any tutorial or example similar to this...
Solved! Go to Solution.
 Dennis_Knutson
			Dennis_Knutson
			07-20-2012 09:23 AM
No, it is not possible to do this with the serial port. The port is not an A/D converter. A simple RS-232 tutorial will tell you that port is binary in nature.
07-20-2012 09:29 AM
Thanks Dennis
