How to read the voltage difference between 2 pins of an RS232?
Hi, I'm new in this field and I'm having a problem in acquiring data from a RS232 port. Actually, I'm not sure if it is possible to do it.
What I would like to do, is to read the voltage difference between two pins of the port. This is because I want to measure temperature (and save the data) in a very simple way. I have 6 thermocouples and I was thinking of welding them to different pins of the RS232 and acquiring the analog signals in mV with the computer. Then, I would use a thermometer to calibrate the values.
Is it possible to do this? How? I've been looking a lot but I cannot find any tutorial or example similar to this...
(3,425 Views)
Accepted by topic author bratidiana
No, it is not possible to do this with the serial port. The port is not an A/D converter. A simple RS-232 tutorial will tell you that port is binary in nature.
(3,422 Views)
Thanks Dennis
(3,417 Views)
