How we can use a
test software developed around 32 bit PCI GPIB Board, Win 98 & VC++ to a different platform having PC/AT with 16 bit AT-GPIB Board ?, though we have already down loaded the driver and thunking dll's from ni.com web. Kind help for solution is requested.Subject :- Help for running 32 bit PCI GPIB based program on 16 bit ISA GPIB card.
Your Ref. : #3545-NGW742
Dear sir,
Please refer to the subject matter with Ref. No. : #3545-ngw742.
We have developed a testing software around NI's 32bit PCI GPIB card and VC++ & Win 98. Now, our requirement is to run the same test software on different PC/AT with NI's 16 bit AT-GPIB card.
In response to our earlier e_ma
il, , regarding above mentioned problem, it was suggested to download the dll files from the web.
We have downloaded the 1) GPIB-32.DLL & 2) GPIB-16.DLL files, but the test program developed around 32 Bit PCI-GPIB could not be run on 16 Bit ISA AT-GPIB board platform and our problem is yet to be solved.
Kindly help us in guiding the correct procedure to tackle the problem, so that the same test software can be transported on both independent platforms (both GPIB boards installed in different PC/ATs) , so that we can run our 32bit PCI GPIB based program on 16bit AT-GPIB card also, if there is any other utility, we would like to download, if required.
We will be thankful for the kind help.
Sincerely yours,
(S. N. Baranwal)
DY. Chief Engineer
Automatic Test System Lab
Research and Development Division,
ITI Ltd., Naini,
Allahabad (UP)- 211010
INDIA.
dceats_nni@itiltd.co.in
Ph.: +91-532-687401
to 687407 Extn. 2573, 2229
FAX : + 91-532-687345, 686008
(3,658 Views)
test software developed around 32 bit PCI GPIB Board, Win 98 & VC++ to a different platform having PC/AT with 16 bit AT-GPIB Board ?, though we have already down loaded the driver and thunking dll's from ni.com web. Kind help for solution is requested.You mean your old AT-bus PC is running Win3.1? And trying to run
your existing Win32 GPIB app there? If the old PC is also running
Win9x or NT, your GPIB app basically runs with both PCI-GPIB and
AT-GPIB without modification.
makoto
"BARANWAL" wrote in message
news:506500000008000000A51A0000-986697009000@quiq.com...
> How we can use a test software developed around 32 bit PCI GPIB
> requested.
> ISA GPIB card.
> Dear sir,
> #3545-ngw742.
AT-GPIB
> card.
> In response to our earlier e_mail, , regarding above mentioned
> web.
> Sincerely yours,
> (S. N. Baranwal)
> DY. Chief Engineer
> ITI Ltd., Naini,
> INDIA.
> Ph.: +91-532-687401 to 687407 Extn. 2573, 2229
(3,658 Views)
