01-27-2010 09:00 AM
I have found that LV 2009 will not open an existing Fowler instrument driver written in LV5.1. I want to see the block diagrams to make a new driver to use with a FV Fowler MarkV Ultra Digit Indicator that uses their OPTO-RS cable. The cable uses rs232 to communicate to a pc.
Solved! Go to Solution.
01-27-2010 09:04 AM
01-27-2010 09:04 AM
If you need help in converting the driver, why didn't you attach it? Otherwise, you will need LabVIEW 8.2 or earlier to open and save it.
01-27-2010 09:44 AM
01-27-2010 10:31 AM
01-27-2010 10:37 AM
01-27-2010 11:21 AM
I went searching for the tread to post new drivers. I found links for posting new drivers and at the bottom of the page was a link for questions or comments which brought up the email link that I previously mentioned.
This may not be the correct approach, but I have searched for other solutions for opening older drivers. I did not find a clear solution or steps to take for a solution.
01-27-2010 11:26 AM
Well, since NI did not write the driver, you may have a long wait for the response, if any.
You need to be a little patient. You have already been told a clear solution. On the pc I'm working on now, I don't have an older version of LabVIEW so I can't do it for a while. You've already been told about the threads on the LabVIEW board where numerous people have asked for conversions. If you don't get a response here soon, post over there. It's more properly a LabVIEW question anyway.
01-27-2010 11:32 AM
jalopy-joe wrote:I went searching for the tread to post new drivers. I found links for posting new drivers and at the bottom of the page was a link for questions or comments which brought up the email link that I previously mentioned.
I'm not sure which thread you're referring to. That email link, I believe, is for submitting drivers to be included into IDNET, not for converting drivers.
I tried to open the driver you posted, but there appears to be a library missing. It is looking for VIs in a library called L1010.llb. Do you have this?
For what it's worth, attached is the library you posted in 8.2. You will not be able to run the top-level VI because of the missing VIs, but perhaps you just need to see the way the communication is done.
01-27-2010 12:02 PM
