IVI compliance package 4.1.0 install error "E:\My Pictures" is not available
I am trying to install ICP4.1, on XP machine with no NI boards or software installed.
The installer says:
This installer needs to access "My Pictures". However, this location "E:\My Pictures" is not available. Ensure that this directory exists and is available and run the installer again.
I do not have any "E:\" drive! so I can not create it!
(6,186 Views)
Accepted by dashesy
Ok I found the problem!
I needed to add this to registery:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders\My Pictures
should have value %USERPROFILE%\My Documents\My Pictures
with type of REG_EXPAND_SZ
(6,158 Views)
Don't you find it a bit odd that you had to do that in the first place? The "My Pictures" folder is one of the folders that gets created when a profile is created. It's possible you may have a corrupted user profile.
(6,142 Views)
Yes you are right. I tend to change many setting on MS Windows and probably I have messed with this folder.
But I still do not know why the installation should need to access My Pictures! I never had problem with this issue. I tried other installations too and all of them had the same problem.
(6,131 Views)
Welcome to the wonderful world of the Microsoft Windows Installer.
(6,120 Views)
Wow, thanks for posting your solution.  Installing the 2009 Run-time Engine I came accross this exact same problem.  The profiles on our lab PCs are often a jumble of different band-aids and quick-fixes too, so I wasn't surprised to have troubles.  But I was surprised to find this post!
I don't know anything about the registry, except that I can access it by typing REGEDIT from Run.  Your guidance allowed me to go in and fix this on all the PCs in the lab.
THANKS!!
(6,051 Views)
