Inconsistent READ output at NI-MAX and Labview for Serial Port Device (mk2000)
Sorry.
I will send them in 2018 later today. I can save for previous version.
Message 11 of 14
(745 Views)
That will be great Albert. Thank you !!!!
Message 12 of 14
(741 Views)
The 20018 versions, just saved for previous
Message 13 of 14
(736 Views)
Accepted by kharkhua
Thanks a lot Albert. Great Help !!!
Turns out that putting a VISA flush block before read solved the issue of lag between command and output. Also I had to manually add ''0A" end line character in hexa display along with command to avoid the errors.
I am sharing a simple code to write and read command for mk2000.Simple W&R code for mk2000Simple W&R code for mk2000
Message 14 of 14
(729 Views)
