12-22-2020 11:30 PM
12-23-2020 12:48 AM
That will be great Albert. Thank you !!!!
12-23-2020 02:33 AM
12-23-2020 04:03 AM
Thanks a lot Albert. Great Help !!!
Turns out that putting a VISA flush block before read solved the issue of lag between command and output. Also I had to manually add ''0A" end line character in hexa display along with command to avoid the errors.
I am sharing a simple code to write and read command for mk2000.Simple W&R code for mk2000
